4efte into a mini shell?
  On 2/13/2013 at 7:53 PM, Jordk said:
A mate of mine was planning this. Apparently the subframes are often known for breaking under load though :/ unless silly strong
That happens in C20LET Novas aswell, usually they just get welded up with an additional brace.
On are you going to need a lengthened fiberglass front end? Similar to whats needed when you do a B series conversion. My mates mini VTEC was an animal, but it did need a lengthened front end to fit it all in and that was only a B16!
Tried fitting the 4efte engine into the mini subframe i have on the Demon but it was stupidly tight, don't get me wrong if you have plenty of time you can get them to fit but i decided to widen the mini chassis in the end to get it all in with a bit more room to spare. Glad i did as now i have a wide ass on the Demon and it looks alot meaner and should be a little more stable.
Seen a few of them in a Mini though and yes they go Very well :D
