Yes I believe so mate, wastegates have nothing to do with gearboxes Haha. You'll need a external gate compatible manifold and to have your turbo modified mate.
someone told me tat radiator pipe is going bang...if i install the screamer....can u tell me which external gate manifold nd turbo will fit?? nd how to install them..
thanx.....
yep my killimats kit I had on my last glanza the autobox got in the way so we had to cut and rotate the external wastegate piping around 360 degrees!
my new kit should be fine thow was just that kit as the wepr kit has the external wastegate at the front I made sure this time lol
PM me mate if you need any advice as I fitted my old set up and it was all kool
I have a WEPR external TD04 kit, when it was auto the screamer pointed directly onto the oil feed and return lines and burst through them so be careful. Also a very tight fit between rad hoses and screamer but a piece of rubber or silicone between them did the trick.
@iamlegend mate can u help me...i want to know glanza automatic pwr manu option...where is the conection located tell me details tat where it goes to ecu gearbox??
