Seals, Gaskets, Timing Belt Kit, Fuel Computer.....etc
Item For Sale: Various gaskets and seals leftover from a genuine toyota engine gasket set.
Item Condition & Description: New
Price: CT9 Oil Feed Gaskets x2 £3 each delivered
Exhaust Seal Ring £3 delivered SOLD
Valve Stem Oil Seals £40 delivered
Crank Oil Seal (Gearbox side) £10 delivered SOLD
Cam Oil Seal £10 delivered SOLD
Injector Seals £17 delivered SOLD
Pm if you want any of the other seals pictured.
Payment & Shipping Details: Posted above
Item For Sale: Timing Belt Kit
Item Condition & Description: New, still in boxes and sealed bags
Price: £40 delivered
Payment & Shipping Details: Included
Item For Sale: Mk3 GT Foglights
Item Condition & Description: Used, good condition
Price: £20 posted
Item For Sale: Head Unit
Item Condition & Description: I had this in my car for less than a month, was just just bought until I got a cable for my new unit. Works fine, comes with receipt and was purchased in October. Does not have a CD player but can plug devices into it and play songs off them via the RCA inputs on the back, the 3.5mm jack on the front, memory card reader on the front or the USB on the front. Comes with remote control and front plate carry case, also has output on the back to run subs.
Price: £25 posted
Item For Sale: Field SFC Hyper
Item Condition & Description: Field fuel computer, all details and instructions of how to fit can be found at http://asia.vtec.net/beystock/field/sfc-hyper
- Fuel injection control can be modified by increments of 1%, changing up to +/- 30%. The fuel injection control can be changed at 7 points on the RPM curve (1000, 2000, 3000, 4000, 5000, 6000, 7000).
-The SFC-Hyper will store up to 3 fuel settings for different driving conditions, and make it easier to compare fuel maps.
Would be a good addition to a car with a FCD and RRFPR to fine-tune the fuelling through the rev range. One button is missing but can still be pressed with a knife or small flat blade screwdriver.
Price: £25 posted SOLD
Item For Sale: Inlet manifold gasket, ct9 water lines, downpipe gaskets
Item Condition & Description: All good condition, inlet manifold gasket is brand new genuine toyota. 1 downpipe gasket has covered around 2000 miles so very good condition, the other is from a turbo I bought and also in good condition.
Price: Inlet Manifold Gasket £10 posted SOLD
CT9 Water lines x2 £7 each posted
Downpipe Gaskets x2 £10 each posted
Item For Sale: 4EFTE dizzy cap + leads
Item Condition & Description: Used, both worked fine on a TD04 @ 1bar of boost. Cap has no cracks, one lead has a small repair but still works fine.
Price: £5 posted each or both £10 posted
Edited by steve-gers
  • 1 month later...
