Weyro Posted February 15, 2013 Posted February 15, 2013 A while back i noticed that running with the o2 sensor unplugged had no effect on the car whatsoever.I changed the o2 sensor and reset the ecu.Ive let the car get a few hundred miles on it and i decided to unplug the o2 sensor just to check, and its the same with the new one, no effect to the car at all. It cant be that they both are broken as the new one is brand new. Any ideas? the car idles perfectly. Quote
akyakapotter Posted February 15, 2013 Posted February 15, 2013 Did your mine per gallon go down with it unplugged ?? Quote
AdamB Posted February 15, 2013 Posted February 15, 2013 You can run the car without one no problem. Funny old things. If it was a wideband however, different story. Quote
Weyro Posted February 15, 2013 Author Posted February 15, 2013 Did your mine per gallon go down with it unplugged ?? No nothing changed at all lol. I have been having an issue with the car running lean when at low revs, off boost and i put my foot down. Quote
AdamB Posted February 15, 2013 Posted February 15, 2013 You only need to worry about the fueling at WOT unless you have a good programmable management system.Check the IAT, CTS and TPS. Quote
Weyro Posted February 15, 2013 Author Posted February 15, 2013 OK will do, I've got a fuel controller on the way.What is an IAT and CTS? My tps is fine, set it up recently.Cheers Quote
AdamB Posted February 15, 2013 Posted February 15, 2013 Intake air temp and coolant temp. Whats your setup? Quote
Weyro Posted February 16, 2013 Author Posted February 16, 2013 Standard InternalsAir Filter RelocationTD04L TurboToyosports Manifold + Decat/DownpipeFull Stainless Catback ExhaustAEM Uego WidebandToyosports FMIC1.3bar Rad CapUniversal rrFPR - 3.2barHKS FCD - setting 8HKS EVC I've Boost Controller - 1bar Quote
AdamB Posted February 16, 2013 Posted February 16, 2013 Have you got an aftermarket fuel pump? It could be that if your running the standard pump, it is failing at that sort of fuel pressure. Quote
Weyro Posted February 16, 2013 Author Posted February 16, 2013 Sorry no its a walbro 255Where on the engine is the IAT and CTS? Quote
AdamB Posted February 16, 2013 Posted February 16, 2013 Have you had it checked on a rolling road recently? I've known quite a few Walbro's to fail. The IAT is in the intake manifold, the CTS is in the thermostat housing (green plug iirc) Quote
Weyro Posted February 16, 2013 Author Posted February 16, 2013 No not had it check, I've been tuning myself with the wideband and only had power runs, I'll book it in once the fuel controller is on.Ah I think I know the CTS, on my car its unplugged because the sensor is a 1wire type but the plug onmy loom is 2 wires Quote
Weyro Posted February 16, 2013 Author Posted February 16, 2013 Is this it? http://imgur.com/KS17u2N Quote
Weyro Posted February 16, 2013 Author Posted February 16, 2013 I've removed the Fcd and put boost and fuel pressure back to standard, now when I'm pulling away and the engines under load it goes full lean until it starts to come out of vacuum. Quote
AdamB Posted February 16, 2013 Posted February 16, 2013 If the CTS is unplugged it will make the car run pretty shit.There are two different types I believe early GT and late GT/glanza. You can just swap the sensor around with the correct one to fit your loom. Not sure if thats the plug but looks familier, its been a while since I've been under the bonnet of my car lol. Heres the sensor :http://www.camskill.co.uk/m19b0s1301p50351/TOYOTA_OE_GENUINE_PARTS_-_Engine_Coolant_Temperature_Sender_-_Starlet_Turbo_05_1997_onwards Orhttp://www.camskill.co.uk/m19b0s1301p48340/TOYOTA_STARLET_TURBO_%28EP82_EP91%29_-_SERVICING_PARTS_TUNING_SPARES_and_SERVICE_ACCESSORIES_-_Engine_Coolant_Temperature_Sender_-_Starlet_Turbo_up_to_05_1997 Quote
Weyro Posted February 16, 2013 Author Posted February 16, 2013 £55 fuck me sideways haha, i hope mine is the cheap one! thanks for the links, hopefully this solves the problem! cheers Quote
