O2 sensor problem
A while back i noticed that running with the o2 sensor unplugged had no effect on the car whatsoever.
I changed the o2 sensor and reset the ecu.
Ive let the car get a few hundred miles on it and i decided to unplug the o2 sensor just to check, and its the same with the new one, no effect to the car at all.
It cant be that they both are broken as the new one is brand new.
Any ideas? the car idles perfectly.
  On 2/15/2013 at 2:18 PM, akyakapotter said:
Did your mine per gallon go down with it unplugged ??
No nothing changed at all lol. I have been having an issue with the car running lean when at low revs, off boost and i put my foot down.
Standard Internals
Air Filter Relocation
TD04L Turbo
Toyosports Manifold + Decat/Downpipe
Full Stainless Catback Exhaust
AEM Uego Wideband
Toyosports FMIC
1.3bar Rad Cap
Universal rrFPR - 3.2bar
HKS FCD - setting 8
HKS EVC I've Boost Controller - 1bar
No not had it check, I've been tuning myself with the wideband and only had power runs, I'll book it in once the fuel controller is on.
Ah I think I know the CTS, on my car its unplugged because the sensor is a 1wire type but the plug onmy loom is 2 wires
If the CTS is unplugged it will make the car run pretty shit.
There are two different types I believe early GT and late GT/glanza. You can just swap the sensor around with the correct one to fit your loom.
Not sure if thats the plug but looks familier, its been a while since I've been under the bonnet of my car lol. Heres the sensor :
http://www.camskill.co.uk/m19b0s1301p50351/TOYOTA_OE_GENUINE_PARTS_-_Engine_Coolant_Temperature_Sender_-_Starlet_Turbo_05_1997_onwards
Or
http://www.camskill.co.uk/m19b0s1301p48340/TOYOTA_STARLET_TURBO_%28EP82_EP91%29_-_SERVICING_PARTS_TUNING_SPARES_and_SERVICE_ACCESSORIES_-_Engine_Coolant_Temperature_Sender_-_Starlet_Turbo_up_to_05_1997
