Hey all, just wondering if it is possible to make the hi/lo boost work with regards to plumbing the vaccumm pipes back in if your running a relocated filte, cause if im corect doesnt one of them run to the standard efi pipe? Just im wanting to put it back but not usre where to plumb it into?
yeah I remember correctly its recirculating so one end comes from the 2nd actuator port and goes to the solenoid and the other from the efi pipe to the other port on the solenoid so you would need either a jam actuator or stock actuator and somehow branch off your relocated air filter pipework
