mark-tozer Posted February 19, 2013 Posted February 19, 2013 im im in low mode which only boosts up to 1 bar and i believe with these when they read 1.00 on the controller they are only boosting 0.90. how do i get it in high mode. thanks Quote
akyakapotter Posted February 19, 2013 Posted February 19, 2013 If you want to run a bar you need to ajust it to 1.10 mate should have said I'd have done it the other day I've got a evc4. there is 3 setting aswell alt will switch between 2 hi and low. there is also a 3rd setting mate sbc is another one that you set to say 1.2bar from anything from 5sec to 30sec and when you press it will go to the set boost for the set time Quote
mark-tozer Posted February 19, 2013 Author Posted February 19, 2013 at the end of the meet sunday i was speaking to towbar and he did say you had the newer one and could adjust it. i was going to ask you but thats when we lost you. ive tryed adjusting it i helled in the sbc button and pressed the high button and managed to get it to 1.10 but then after want back to display screen was only boosting to 0.9 it seems to be still in low mode how do you get yours in to high. Quote
akyakapotter Posted February 19, 2013 Posted February 19, 2013 Ill have a look at mine tomorrow and ill let you no mate Quote
