steve-gers Posted February 23, 2013 Posted February 23, 2013 Trying to diagnose my clutch problem today and took a quick video of the movement of my slave cylinder (link below). Could somebody have a look at there cylinder aswell and have a look to see if this amount of movement is enough to push clutch or whether it is not. Thanks. http://www.youtube.com/watch?v=lIvjLeX2wA4 Quote
StuDoc 72 Posted February 23, 2013 Posted February 23, 2013 Its hard to say mate less movement than you think is needed what exactly is wrong is the clutch not disengaging at all? Quote
steve-gers Posted February 23, 2013 Author Posted February 23, 2013 When the pedal is on the floor it is basically engaged around 10-20% (at a guess) no slipping at all through the gears in boost though. Must be the clutch broke up or fecked bearing but the bearing is not and has never been noisey. Quote
rmsnoel Posted February 23, 2013 Posted February 23, 2013 Pull the rubber boot back on the slave cylinder on front of the gearbox and check for leaks. Give it a quick bleed and test again Quote
StuDoc 72 Posted February 23, 2013 Posted February 23, 2013 Shorten the rod on the pedal inside the car buddy that probably the issue. After you've checked for leaks and bled of course. Quote
steve-gers Posted February 23, 2013 Author Posted February 23, 2013 No leaks behind boot, will bleed tomorrow and see. Ut went from being fine to fecked without notice so just a bit strange. Quote
StuDoc 72 Posted February 23, 2013 Posted February 23, 2013 Try adjusting the pedal and see if that helps mate all you need is a 12 or 14mm spanner worth a shot. Quote
steve-gers Posted February 23, 2013 Author Posted February 23, 2013 Yeah al give that a try if bleeding doesn't work cheers. Quote
tiksie Posted April 24, 2013 Posted April 24, 2013 hey bud Having the same issue What ended up being the problem ? Quote
