I used my n/a tb on a Glanza inlet so i wouldnt see why not. And i dont think i used anything other than abit of silicone hose to replace the old one that comes out the rocker.
Did that inlet work alright then mate?
nothing man, but i had the n/a throttle cable holder welded to the corolla throttle cable holder, although i'm sure there's a way around it with a certain washer or something.
U just need alittle more vacumm pipe for the map sensor. Use your standard throttle.body
Attach the earth wire to the throttlebody as youll notice it doesnt fit on the corolla manifold. Use gasket seal as these manifolds dont seal great even with new gaskets. Glanza manifolds are only good from 5000rpm+... Corolla manifolds rule
Edited by rmsnoel
Did u get the rubber holder thing for the throttle cable. You have to takeup the slack in the cable to keep yor throttle crisp n responsive. View photo in my build thread
Man if its not fitted yet would u mind measuring the opening for me. Im making an adapter to fit a 50mm throttlebody and it would save me removing mine
If u offset your rubber piece it will reduce the slack in the cable caused by fitting a rolla manifold
The metal plate that.holds the throttle body, I want to know if the big hole is 45mm or 43mm or 47mm. Yiu offset the bush,by cut away 1mm of rubber from ome side. Oil or wd40 on a hacksaw or bread knife does the job. Take a look at the photo on my build.thread to see what I mean
Does the idle drop after a while? I know mine starts at 2k for around 5 mins then drops to 1k.
Maybe adjust the idle screw or I've heard some people speak of a sticky idle control valve?
