  • Replies 70
  • Created
  • Last Reply
Top Posters In This Topic
get them sent back bud, i now when the meister r coilovers came out on the gen7 celica they sat similar to this and a gen2 set had to be designed. may be the same issue with these
I've passed on basically what Cj told me when I had the same issue with rear hight seams to perform perfect thou tbh
It can be dangerous.
Maybe shorter springs would help you go lower (safely).
pre-load messes with compression etc of the damper stroke something along the lines of that for weight transfer when braking and accelerating im not too clued up on it but i do know that....it has no use on a street car and should be left alone (should actually come pre-set when you buy them)
as idrees said i can be dangerous, get in touch with CJ im sure they will sort it
The cars my daily and I've sold my standard setup so I'm in the shit really, I could ask the machining shop we use at work if they'd shorten the threaded tubes but ill be out of pocket then.
ive emailed dgr guys will get them to send out either shorter springs or complete units to resolve it :)
Nice one James, I'm having it all aligned after work so can I keep the front ones and just send the rears back if I have to so I don't have to get it all aligned again?
Think it would change again mate the lower you go on the back you need a adjustable panhard to pull the wheel back in I'm waiting to have this done glad I didn't if going to b getting shorter spring or shock
Yh I got a cusco adjustable panhard there is a thread on panhards in suspension section everyone recommends them 100 pound new I think they are I got mine second hand think was 75 posted
You shouldn't need alignment doing again. It's easy to adjust panhard rod yourself, doesn't have to be exact like the front. I mean most of the forum probably drives lowered cars without an adj panhard rod at all!
Is this gonna be the same for people just buying these or will the issue be resolved in the ones on the group buy as its slightly put me off if I'm gonna have problems with them
Dont do your alignment until you have the suspension set up. Its a waste of time.
They will use guages on the back and front wheels to set them up and if they are doing full set up will adjust the camber also.
Bringing down the back end will then upset all of this.
When doing alignment the 1st thing you do is check tyre pressures. If a few mm in your tyre wall makes a diff then it sitting like a monster truck at the back will send it way out.
I 100% would wait untill its all done 1st.
