one of my intercooler pipes around the bottom came off without me fully knowin and i drover the car without boost
and everytng was grand it started reving without me doin anytng then i turned it off quickly and look underneath
and the pipe that was direct to the inlet mani had sucked up sum dirt ? icon_sad.gif
nd now wont start ????????????????
wat will i do ?
Have you taken the inlet mani off to see if there is any visable dirt contamination in the head or the inlet?
If you have sucked up any water you may have bent a conrod or if it was just dirt and grit you may have damaged your valves/seats.
when u try to start the car does it still turn over or does it get stuck?
