Danza V Posted March 4, 2013 Posted March 4, 2013 Basically since my glanza decided to blow oil all out of my breather I've had to buy a new car and don't boo me please its a vw passat 2.0 estate mainly for the wife and dog but anyways... At idle in neutralil get a very slight vibration or bump through the body but it drives fine, no codes Nd idles at a steady 750rpm... I found a small hose which comes off the intake pipe to the gearbox :/ and was split wide open I mean I will fix this but surely that should cause the engine to stall... Right?? Cheers guys Quote
Glanza-Ben Posted March 4, 2013 Posted March 4, 2013 That pipe is the crank case breather if I remember right and can cause the engine to over fuel and stal and run crap just changed my dads as his had fell to pieces Quote
Glanza-Ben Posted March 4, 2013 Posted March 4, 2013 Just re read and that ain't the crank case breather but sounds like a breather or part of the pcv system which then if split again will make it stall etc Quote
Danza V Posted March 4, 2013 Author Posted March 4, 2013 The pcv one was also completely missing so I put a spare bit of pipe I had on there and tightened it down with some clips.. The one in question connects straight on to a valve of some dirt on intake and is that badly perished it's not even connected.. Strange that it doesn't stall or cause any issues at high revs just at idle. Quote
Danza V Posted March 4, 2013 Author Posted March 4, 2013 I need to get back into a jap seat asap!! The glanzas looking very sad Quote
Starlet SR Posted March 4, 2013 Posted March 4, 2013 Dual mass flywheel vibrating possible if its diesel ? Quote
DaveyDemolition Posted March 5, 2013 Posted March 5, 2013 I just bought a 2.0 Porsche 924 and the exact same thing happened too me, the pipe was split, I taped it up and it hasn't cut out on idle since Quote
james@cjperformance Posted March 5, 2013 Posted March 5, 2013 I just bought a 2.0 audi 924 and the exact same thing happened too me, the pipe was split, I taped it up and it hasn't cut out on idle since knew you finally admit it Quote
Danza V Posted March 5, 2013 Author Posted March 5, 2013 Nah 2.0 petrol.. Cheers guys cang get my fecking hand in there though:( Quote
Danza V Posted March 5, 2013 Author Posted March 5, 2013 By the way @ Daveydemolition what is that actual pipe and what does it do? i mean it comes from teh box to the intake pipe i know and it goes onto a sensor? what is that?? how did you tape that fucker its right tucked away lol.. Quote
