Hi,
I've recently been looking into the TD04 conversion. Seen all the manifolds, downpipes etc from WEPR (any good?) and the turbos aren't too hard to get hold of.
Now before I even think about buying any of this stuff, what should I do engine wise to ensure everything is running right.
At the moment its all standard.
I'm after a basic list list of things that will need to be changed/uprated for the conversion.
Ta
you will need a decent fuel setup.
so at a minimum thats a uprated fuel pump, bigger injectors (330s or bigger, depending on what power youre after) rrfpr and a piggyback. if you got the money get a stand alone unit.
you may aswell get a fmic while youre at it.
and depending on how much boost youre running id suggest some forged pistons.
then a good tune.
thatll all cost you 1500-2000 quid.
A few of his manni's have cracked. However, a lot of variables are involved.
Stainless has better flow characteristics, but holds heat longer than mild and is not good with expansion.
Mine has been on for well over a year and neither the manifold or downpipe have cracks.
I did invest in TRD engine mounts and an engine brace before hand thou.
As above thou mate, fueling is the main thing.
