GlanzaVLez Posted March 5, 2013 Posted March 5, 2013 just bought a kmh to mph converter, How do you fit these things?!? Quote
StuDoc 72 Posted March 5, 2013 Posted March 5, 2013 Unscrew the speedo cable which goes into the gearbox. Screw it onto the convertor and screw the convertor onto the gearbox where the cable went. Make sure the cable doesnt come out too far or it will come out the back of your dials and youll need to pull them out and put it back in and it just becomes a pain in the tits. Quote
GlanzaVLez Posted March 5, 2013 Author Posted March 5, 2013 See there's knowhere for it to screw on the gearbox where the line comes out of? Quote
StuDoc 72 Posted March 5, 2013 Posted March 5, 2013 What? Your speedo cable goes into the box just now. It has a metal collar on the end that is the part that unscrews and comes off the box. Have you just pulled the cable straight out of that? Quote
GlanzaVLez Posted March 5, 2013 Author Posted March 5, 2013 Well I unscrewed it off, and it's left with the part it slots into with 2 or 4 screws on it Quote
morgey Posted March 5, 2013 Posted March 5, 2013 Get some pictures up of what you're unscrewing mate, we will be able to help you out better Quote
rmsnoel Posted March 5, 2013 Posted March 5, 2013 You have unscrewed the wrong part by the soinds of it. The speedo cable comes out by hand. Its a piece of metal pipe on top of the gearbox, almost direct below your throttlebody. Unscrew it by hand if u can and thats where the speedo goes. Ad said before make sure the cable doesnt slife out too far or it will disconnect from the clocks in the car. You can put it back in by pushing the.cable.back in gently and twisting it.left and righy until u feel a click which will be the other end of the cable locating into the clocks againSiunds like u unbolted the gear selector Quote
