scutch0 Posted August 8, 2007 Posted August 8, 2007 what compression readings should i be getting from a 4efte using a compression tester? Quote
Guest Enzo Posted August 8, 2007 Posted August 8, 2007 155-175 and you should be have a healthy enginewhat are you getting? Quote
scutch0 Posted August 8, 2007 Author Posted August 8, 2007 i havent tested it yet bud. but i'll let you know what i get when i do.should be some time next week. Quote
lobotomy Posted August 11, 2007 Posted August 11, 2007 The main thing is they should all be within a certain tolerance of each other... unless you've got a major problem. Also take the readings a few times over and average them. Quote
