PokerFace Posted March 12, 2013 Posted March 12, 2013 has any 1 fitted wheels and tires in this size? curious about rubbing and clearance, i reccon should be fine with rolling the arches ? Quote
Amjad Posted March 12, 2013 Posted March 12, 2013 Should be okay if you roll the arches and run 195 tyres. 225s are very wide for our cars Quote
PokerFace Posted March 13, 2013 Author Posted March 13, 2013 going for r88 225 tires up front to try get power down and better corner grip on track, seeing alot of track civic's in the states using 8/9 j's with 225 hence the ideai know its a big tire but its for a purpose Quote
Amjad Posted March 13, 2013 Posted March 13, 2013 I'll say you'd struggle, might be worth speaking to the Cypriot/Irish guys as some of them run drag tyres that are quite large 205s will have been plenty I'd have thought as most of us run 195. Rbz has 205/50s and he had to roll his arches Quote
Burny Posted March 13, 2013 Posted March 13, 2013 I own a civic and a glanza and 8J is a big no no... Quote
Amjad Posted March 13, 2013 Posted March 13, 2013 8J can fit, it's the offset and tyre width/thickness that matter more in this case. The offset is sensible but the tyre width OP wants is really wide Quote
Burny Posted March 13, 2013 Posted March 13, 2013 He mentioned civics in the states running 8/9J, i tried 8J myself and its ridiculous on the civic and a complete pain, in the states they are mad for it but would have had a lot of arch work done Quote
Amjad Posted March 13, 2013 Posted March 13, 2013 Hmm I'd have though 8J on a Civic wouldn't have been too much of an issue! Quote
PokerFace Posted March 13, 2013 Author Posted March 13, 2013 He mentioned civics in the states running 8/9J, i tried 8J myself and its ridiculous on the civic and a complete pain, in the states they are mad for it but would have had a lot of arch work done i take it the wheels were a very low off set? most 8j/9j 15inch wheels have very low off sets, there are very few wheels that offer a bigger offset in these but these track wheels im going for offer a bigger offset which is perfect for putting a wider tire on, i supose it will be trial and error ill give the 225's a go and post the results here this is how the 8js with 225's fit on a civic with rolled arch Quote
Burny Posted March 13, 2013 Posted March 13, 2013 Personally on a civic the ideal fitment IMO is 16x7 +42, on a Glanza im using 15x6.5 and have had my arches rolled and used spacers to get the tyre flush with the arch for the perfect stance Quote
AdamB Posted March 13, 2013 Posted March 13, 2013 A wider tyre doesn't give you more grip either by the way, only creates drag. The cruise demo glanza used to run a 225 profile, on Advan RG rims I think, that might be worth a look. Quote
PokerFace Posted March 13, 2013 Author Posted March 13, 2013 A wider tyre doesn't give you more grip either by the way, only creates drag. The cruise demo glanza used to run a 225 profile, on Advan RG rims I think, that might be worth a look. correct but will give me gains in the corners round knockhill, im going to try it my self as i havent seen any 1 else using these wheels and tire combo Quote
AdamB Posted March 13, 2013 Posted March 13, 2013 What gains would you get? It only allows the tyre to run cooler, which is no good when trying to get grip. Plus an 8j rim isn't going to be light. Quote
PokerFace Posted March 13, 2013 Author Posted March 13, 2013 they are 5.8 kgs each, they are used on many time attack fwd cars, i am going from the set ups they are using for grip Quote
Burny Posted March 13, 2013 Posted March 13, 2013 Your choice dude but personally i think they would piss you off, especially doing track time the tyre would constantly be hitting the arch, and as Adam pointed out it will create more drag, if 8J's were the way forward then you wouldn't be asking these questions, fact is its an uncommon size due to hassle... Quote
EP-Azz Posted April 20, 2013 Posted April 20, 2013 Would 15x8j et30 with 195/50/15 r888s be okay? Quote
