Have eml light on my glanza and doing a diagnostic it comes up code 31 which is map and 52 which is knock sensor . Il replace the knock sensor but what do I do about code 31 or are they linked ???
The knock sensor is damaged I put it on and it was my brothers old one that he replaced I didn't know - I've recently put a fcd on would that be anything to do with code 31 ?
you cut the wire for the map sensor to fit a fcd, so possibly
I've sorted code 31 I'm only running 0.8 boost it doesn't go any higher I re connected the wires and took the terminals off the battery and the code was clear took the car out tested it again and just came up code 52
