It's an easy job mate, I've done mine and my brother's. Just be careful with removing the gas! Obviously :) also don't forget you will need a different pas belt. I'm sure you knew that but thought I would mention it.
read the guide!!
yes you could keep that belt on BUT means you wont remove the a/c pump or brackets which are heavy as fuck! also still more strain on the engine!
just get the shorter belt 7 quid from idrees and jobs a good un!!
dont sound too bad then. how dyou bridge the gap or whatever so my fan isnt always running on my gt?
are you reading this guide hahaha
there will be a grey connector on the a/c bridge that to the plug in the engine bay..
this grey plug I think it was ages ago when took it from my GT
Edited by iamlegend
