Starlet gt engines stronger than glanza engines?
Both the same, iirc someone had them tested glanza rods are thinner but made of stronger material
As Ryan said, the pistons are the weakest point if fueling/boost/timing isn't spot on
Its true toyota did it with the 4AGE's as well, but if your not revving the tits off of it i wouldn't worry. 4ages are ok on stock rev limits 8400rpm(ish) if i want to rev more i want to put shot peened silver top rods or forged aftermarket rods in.
As ryan said seems the ringlands on the pistons would usually go first. If your doing the rods change the pistons for forged and visa versa ;)
