Hi guys, is this a common fault on starlet gt's by any chance? where the mount for the standard recirc valve/breather recirc enters the intake pipework?? I cant figure out whether mine has been bodged up, or its meant to detach around the base where it enters the intake pipework as its got some shitty sealant all over it..
you can see it opens up a good 1mm in the second pic.. i thought she was loosing boost somewhere.. this has to be it.
anyone else had the same problem?
