Im breaking a gt i was wondering has it got an lsd box as it pull right through bends ,
If it does i dont think its an oem lsd as when jacked up both wheels spin opposite directions, also doesnt look like lsd but goes around bend like nothing else
How can i find out?
No matter what lsd even if aftermarket it will spin opposite?
Must the the gab adjustable shocks then that give it the handling:)
nope not all!!! only way to find out, is to pull the driveshafts out...
an OEM lsd box has it on the outside so should be visible from the outside, an aftermarket lsd is not visible from the outside ;)
No just pull shafts out and look through the hole. If there is a bar its non-lsd if anything else its LSD (most are see through) post a pic here if unsure.
