Hi,
Can someone explain to me what the difference is between an adjustable Fuel Pressure Regulator and a Rising Rate Fuel Pressure Regulator.
I currently have an adj. FPR installed and I will most likely have my AEM wideband setup installed soon so I can set the boost pressure higher with a good A/F ratio.
Just curious to what the difference is and what FPR will be best to have a good A/F ratio troughout the whole RPM range @higher boost (0.9bar, ct9)
Thanks,
Jurr
