Lew91 Posted April 8, 2013 Posted April 8, 2013 (edited) So after fitting the apexi ecu with maf to check it all works fine, which it does we put the original ecu back on but it now runs like shit. Is this a standard ecu or is it after market and needs to relearn again after unplugging? Cheers Edited April 9, 2013 by Lew91 Quote
Lew91 Posted April 8, 2013 Author Posted April 8, 2013 Was slightly confused about the 2 boards but I've never seen inside an ep82 ecu before :/ ?? Quote
turbo Grant Posted April 9, 2013 Posted April 9, 2013 that's standard to have 2 boards one bolts to the top the other to the bottom. I find after plugging an ecu back in it takes a few days to settle down Quote
Lew91 Posted April 9, 2013 Author Posted April 9, 2013 Ah right it could be that then, it just seems weird how nothing has changed yet it won't run properly. It seems like it misfires all the time. Quote
