Joe20 Posted April 13, 2013 Posted April 13, 2013 yooo , can you get aftermarket cams for glanzas ? never really thought about it but i was n/a with the old french scene GTI and VTS and the aim was to cam and map and bodied etc and theres hundreds of cams for them fast road ones like newmans ph3 and kent cams piper cat cams 708 etc can you get them for glanza's ? even if you did would it do much ? cheers joe Quote
shorty Posted April 13, 2013 Posted April 13, 2013 no massive gains till over the 300-350mark realy as the stock valve train is quite good tbh. as for availability a ew jdm conpanys made some but they are expensive and rare and expensive to fit due to be a regrind. the only other option is billet cams but again not a cheap option amd atm not an off the shelf product but thier are companys and traders on here who can obtain billet cams if your setup will require them. not a hugely common mod in the starlet scene though as more power for less money can be achevived else where in the specs of the engine/setup Quote
5e colin Posted April 13, 2013 Posted April 13, 2013 (edited) i beg the difrence lad a good race cam does difrence it depends only how high u rev ( not on the ct9 offcourse ) / if your only on stock rev limit 7,2 then stick to oem cams if your above that 8 or 9 k then yes better of whit difrent cam Edited April 13, 2013 by 5e colin Quote
