AndyMB Posted May 10, 2013 Posted May 10, 2013 how to find the offset at +45? Do you run any spacers or anything?I have these wheels, I believe that offset is right. I don't run spacers at the moment but probably will at some point. They sit lovely at the front without, could run a 5mm spacer at the rear if you wanted a flusher fit. Hope that helps Quote
Spoon_tuned Posted May 10, 2013 Author Posted May 10, 2013 I have these wheels, I believe that offset is right. I don't run spacers at the moment but probably will at some point. They sit lovely at the front without, could run a 5mm spacer at the rear if you wanted a flusher fit. Hope that helps thanks alot mate Quote
