Looking to get my tongs ct9 rebuilt as it was smoking a lot is I believe the seals are gone. Where snouts will rebuild turbos? And at what cost?
I had mine rebuilt by glasgow turbo specialists. Actually was a nightmare replaced the seals twice and it continued to smoke.
Turned out it was the bearing housing that was cracked to had to use the housing from another ct9 I had.
Got a newer bigger comp wheel in mine plus a larger exhaust wheel along with the bearing housing changed and the seals replaced.
I obviously supplied the bearing housing but they provided the rest I also took the turbo off aswell but this isnt advised always as they then cant test it which was part of my problem.
Ended up costing £330 for me which is actually a very good price for the amount of work I had done and the guys are bang on and were very patient with my endless troubles.
