Jordk Posted April 22, 2013 Share Posted April 22, 2013 Looking to get my tongs ct9 rebuilt as it was smoking a lot is I believe the seals are gone. Where snouts will rebuild turbos? And at what cost? Quote Link to post Share on other sites
StuDoc 72 Posted April 22, 2013 Share Posted April 22, 2013 I had mine rebuilt by glasgow turbo specialists. Actually was a nightmare replaced the seals twice and it continued to smoke. Turned out it was the bearing housing that was cracked to had to use the housing from another ct9 I had. Got a newer bigger comp wheel in mine plus a larger exhaust wheel along with the bearing housing changed and the seals replaced. I obviously supplied the bearing housing but they provided the rest I also took the turbo off aswell but this isnt advised always as they then cant test it which was part of my problem. Ended up costing £330 for me which is actually a very good price for the amount of work I had done and the guys are bang on and were very patient with my endless troubles. Quote Link to post Share on other sites
Liam_D Posted April 22, 2013 Share Posted April 22, 2013 I work at Midland Turbos matey, let me know if its something you want a hand with http://www.midlandturbo.com/?gclid=CLfmsYWJ37YCFRLLtAodXhIAng Quote Link to post Share on other sites
