Panda.gt Posted April 29, 2013 Posted April 29, 2013 So I glad to say I've brought myself another ep82 not stop smiling since I picked it up.I've had a Cusco LSD in a box in my garage for about a year that I never got to put in my previous ep, now I want to put it in my new one but can't find anywhere trust worthy of getting oil and the correct oil can anyone help? Thanks!! Quote
AdamB Posted April 29, 2013 Posted April 29, 2013 You don't have to use the cusco LSD oil mate. Check out opie oils, the Motul, fuchs and redline stuff is pretty damn good at keeping them quiet so I've heard. I'll probably use the Motul stuff in mine. Quote
Jamie_VF22 Posted April 29, 2013 Posted April 29, 2013 I use this with my cusco diff http://www.opieoils.co.uk/p-888-motul-90-pa-lubricant-limited-slip-differential-lsd-extreme-pressure.aspx Quote
TurboTobz Posted April 29, 2013 Posted April 29, 2013 Silkolene silk trans race oil I used for my cusco 1.5way Quote
jayc-glanza17 Posted April 29, 2013 Posted April 29, 2013 im my cusco I use exact same as Jamie posted above..Motul which we use was recommended by the late Dave Burwash. Quote
Jamie_VF22 Posted April 29, 2013 Posted April 29, 2013 im my cusco I use exact same as Jamie posted above.. Motul which we use was recommended by the late Dave Burwash. Dave burwash recommended it to me aswell jay He used to run cusco one in the GT with this oil Quote
g14nza Posted April 30, 2013 Posted April 30, 2013 I'm havin problems with my car since the rebuild I had a cusco diff fitted with mike at Td bout 6 months ago finally get to drive it and it makes a seriously nasty clunk when turning accelerating/ de acceleration an changing gear could it just be cv joints or the wrong gearbox oil I'm using 75-90 fully synthetic Motorsport oil?? Should I just try the oil that's linked above? HELP Quote
TurboTobz Posted April 30, 2013 Posted April 30, 2013 Cusco's make that noise at low speed cornering 30 ish mph*+ they usually stop. It's perfectly normal some oils can quiet these a little. I miss my clunky Cusco! Quote
g14nza Posted April 30, 2013 Posted April 30, 2013 Okay ill trust your word gotta try do 400miles before gettin her mapped Quote
TurboTobz Posted April 30, 2013 Posted April 30, 2013 I had the cusco 1.5 way mz, although it shouldn't clunk changing gears iirc is it possible that noise is coming from elsewhere? They should only clunk at slow speed cornering.http://www.toyotagtturbo.com/forums/showthread.php?43912-cusco-LSD-clunkJust to put your mind at rest^ Quote
AdamB Posted April 30, 2013 Posted April 30, 2013 They will knock/clunk until the initial torque has activated the LSD. Quote
Panda.gt Posted May 12, 2013 Author Posted May 12, 2013 I use this with my cusco diff http://www.opieoils.co.uk/p-888-motul-90-pa-lubricant-limited-slip-differential-lsd-extreme-pressure.aspx'>http://www.opieoils.co.uk/p-888-motul-90-pa-lubricant-limited-slip-differential-lsd-extreme-pressure.aspx Thanks Jamie and guys! Just ordered some and hopefully put the box in next weekend! Quote
