riko666 Posted August 29, 2007 Posted August 29, 2007 Some of you may have seen this thread on TGTT, but anyway, get help where I can...basically, after not having driven the car in close 2 months the car is running like ass. On start up it is lumpy as...well...a "Cammed" V8, literally shaking the car, and belching out lots of black, rich of petrol smoke. When warm, the idle is even lower (around 500rpm as opposed to 800rpm when cold) and usually stalls...Now I know it could be the petrol having deteriorated in the time, but I've put in a bottle of Fuel System Cleaner and a Quarter tank of new petrol (was nearly empty before), and no difference. Have also cleaned the Idle Control Valve, no real change. I have been advised to clean my injectors which I will do soonish but apart from that what could it be?What strikes me is how the runnign condition can go so bad, when previously with the 5efe and 5efhe I had no such issues? True, if it's the fuel injectors I figured the particulates in the petrol that typically would just flow around the injectors, would have settled down on switching off the car, completely clogging the injectors, but it's peculiar. I do not believe it'll be the Ignition system as it's all "newish", the battery is crap really, but it isn't flat, and I have no ECU light on so doubt it's a question of Faulty sensors either. Any and all help is much appreciated, thanks Quote
Guest Enzo Posted August 29, 2007 Posted August 29, 2007 this could be anything man, ive known new ignition leads to go after a few months of use, check your plugs to see if there is any residue of rust,after that get some forte engine flush maybe?you say uve used injector cleaner already yea? Quote
riko666 Posted August 29, 2007 Author Posted August 29, 2007 used injector cleaner, some new petrol, cleaned the Idle Control Valve with Carb' Cleaner...I'll go check the plugs/wires/distributor cap now, as well as clean the Injectors...I just don't understand why after 2 months of non-driving it acts like this? My other engines have never done it... Quote
riko666 Posted August 29, 2007 Author Posted August 29, 2007 ok, what I can confirm is that the spark plug tubes smell of "damp" and most of them are quite rusty...moisture seeping causing a bad spark? Anyway, I wire brushed each spark plug, and after putting them back in, put some WD40 in them and onto the ends of the Spark Plug Wires. I also removed the injectors, Doused them in Carb' Cleaner and cleaned the surrounding area on the intake manifold. I may check the distributor cap after the WD40 has dried from the Spark Plug tubes..but otherwise, I've just got fuel filter left to checkBy the way, does anyone have a spare Fuel Injector O-Ring they can send a.s.a.p? I've misplaced one Quote
Idrees Posted August 29, 2007 Posted August 29, 2007 Yes Riko I do. Won't be able to get it out till Friday after college though.. Quote
riko666 Posted August 29, 2007 Author Posted August 29, 2007 aaaargh, any chance of getting it out asap? I will give you....£2.07! Should be fine in an envelope! Quote
StarletRick Posted August 30, 2007 Posted August 30, 2007 have you changed the oil? it wont be the reason for the shite idle, but you should change it...also, reset the ECU. Quote
riko666 Posted August 30, 2007 Author Posted August 30, 2007 yeah I'll change the oil once the car is working, haven't changed in a good few 1000mi...and ECU has been reset countless times Quote
riko666 Posted August 30, 2007 Author Posted August 30, 2007 ugh, well, anyway, when the WD40 dries out i'll try firing up the car and see what's changed...if nothing, would someone in the area be kind enough to come up and help me with this? I'm getting so sick & tired of the car now... Quote
DaMaGe Posted August 30, 2007 Posted August 30, 2007 Have you tried a diagnostics check mate ? That would have been the first thing I tried mate. Quote
riko666 Posted August 30, 2007 Author Posted August 30, 2007 Diagnostic port doesn't seem to work One of the first things I tried Quote
riko666 Posted August 31, 2007 Author Posted August 31, 2007 Ok, an update:So as I said, I wd40'd the spark plug tubes, wire brushed the spark plugs, wd40'd the spark plug wires, cleaned the fuel injectors....And still the same shit. I touched the screwdriver on the injectors, and it was hard to tell as the rough idle shook the engine loads, but I believe all of them are clicking, so no injector is stuck open...So where to now? I'll check the fuel filter & pump tomorrow but what am I looking for? And after that what are my other possibilities? I want to change the oil (keep the filter) too for safe-keeping. I think it could be what was stated about the sensors, would make sense - or a cold start sensor that's not turning off? But regardless, it runs SOOO rich...it's driving me mad. Not a single moment's rest with this thing...really getting me annoyed.... Quote
