Nope, the turbo uses a 212mm clutch, the N/A uses 200mm. They are interchangeable on the crank though, so you'll just have to use the correct clutch with the right flywheel.
I believe some of the oversea's people use the N/A 200mm clutch on high powered 5E's, they don't to seem to have a problem :)
Old 4ages have 200mm clutches. Newer ones are 212 and I know the 212mm ones are the same as 4eftes
I wouldnt be surprised if theres some upgraded ones for the 200mm 4ages you could use.
Saying this i have a lightened 212mm 4age flywheel here if you're interested?
Edited by morgey
Not sure if the fly is the same, but the clutch from an MR2 can be used as well :thumbsup:
