i bought a glanza engine or my ep82 and out it in I've done all the wiring and there are 3 wires that have no place to go. Anyway I put everything else on and it starts up over revs a bit and when you go to the boost the boost sits a -2 psi and then goes to 4 psi and starts like choking like a misfiring noise. It also says it's over heating aswell. can anyone help
cheers
nath
Check the thermostat area for any loose/broken wires. This is one area where sensors differ between the two engines.
cheers for that boys. right another problem I've put what was on my engine onto this engine it now ticks over at -6 boost and rev at 0.4 boost it feels like its struggling to get fuel but has set up just like the old engine. I've been told to get the timing change nod get a gauge on fuel pressure regulator. any suggestions on why it may be need as much help as possible
cheers
