Anyone know which type of TPS a EP91 Glanza V has?
Got a hesitation problem through the lower revs <3k part throttle is when its more apparent.
Cheers ill see what results i get. Read somewhere else the car could have 2 Lamba sensors. Do you know if this is correct? Sure mine has one only.
Ok thanks, maybe a couple of sensors need renewing.
MAP sensor, allready changed Lamba, is there an Air temp sensor?
After the TPS ill be struggling. Had the Lamba up its back side, showing low fueling when its holding back.
Maybe a fuel pump issue haha theres a few to go at. Just strange how its fine on full throttle on boost.
Not sure on turbos but n/a's have a black plastic cone shaped thing that sits in the intake pipe for aur temp.
Also i think the coolant temp sensor to the ecu might be worth checking have heard them causing cars to spud out
Right thats another one then, can see how that would mess with the fueling, so may renew that aswell.
Is the TPS a potentiometer?
