Lawless Posted May 5, 2013 Posted May 5, 2013 The little black pipe that's connected to the efi pipe will it be inactive as I will have no where to plug it In or do I loop it to somethingCan some one shed some lightThanks Quote
jimmymac101 Posted May 5, 2013 Posted May 5, 2013 I beleave it's vented to atmosphere mate On glanza you loop across the hi low boost solidoid and leave the one by the block to atmosphere can't be far off for an ep82 James Quote
Lawless Posted May 5, 2013 Author Posted May 5, 2013 I've removed the old recirc valve from the pipe and put a breather filter on the rocker but there was also another pipe connected to the efi pipe that leads off to some sort of sensor box (I don't no what it is ) Quote
Lawless Posted May 6, 2013 Author Posted May 6, 2013 I think he means this part[/quoteThat's the area and there would usually be a metal part with three tubes that runs up the side of the rocker Quote
