im guessing the one on the right is the coolant sensor ? but if anyone has the plug for the one on the left it would be helpful :p
The one on the right is the coolant temp sensor the one on the left Is the rad fan switch the small spade terminal is the other coolant temp sensor and both feed the ecu. On later models they have a 3 pin triangular temp sensor these do the job of both temp sensors
I've got a brand new temp sensor somewhere and I've probably got a fan sensor plug to on a spare loom. Ill try and have a look at some point.
Hth
Rob
Hth
Rob
if you could mate that would be great and verry much appretiated im missing it alredy :)
