PhilGT93 Posted May 13, 2013 Share Posted May 13, 2013 as title says for ep91 end cap is for drivers side and black would be great but any will do cheers Link to post Share on other sites
rob_bower Posted May 13, 2013 Share Posted May 13, 2013 Which shape sensor as there are 2 different ones. Link to post Share on other sites
PhilGT93 Posted May 14, 2013 Author Share Posted May 14, 2013 Not sure I think its the green one not white if the colours are the shapes but I'll check after work Link to post Share on other sites
steviet Posted May 14, 2013 Share Posted May 14, 2013 Got a side skirt end cap from Toyota one time,and if memory serves me right it wasn't deer. Link to post Share on other sites
asbo-v Posted May 14, 2013 Share Posted May 14, 2013 Got them all pm me Link to post Share on other sites
PhilGT93 Posted May 14, 2013 Author Share Posted May 14, 2013 im guessing the one on the right is the coolant sensor ? but if anyone has the plug for the one on the left it would be helpful Link to post Share on other sites
micky boy Posted May 14, 2013 Share Posted May 14, 2013 The other one is the ecu temp sensor Link to post Share on other sites
rob_bower Posted May 14, 2013 Share Posted May 14, 2013 The one on the right is the coolant temp sensor the one on the left Is the rad fan switch the small spade terminal is the other coolant temp sensor and both feed the ecu. On later models they have a 3 pin triangular temp sensor these do the job of both temp sensorsI've got a brand new temp sensor somewhere and I've probably got a fan sensor plug to on a spare loom. Ill try and have a look at some point. HthRob Link to post Share on other sites
PhilGT93 Posted May 14, 2013 Author Share Posted May 14, 2013 The one on the right is the coolant temp sensor the one on the left Is the rad fan switch the small spade terminal is the other coolant temp sensor and both feed the ecu. On later models they have a 3 pin triangular temp sensor these do the job of both temp sensorsI've got a brand new temp sensor somewhere and I've probably got a fan sensor plug to on a spare loom. Ill try and have a look at some point.HthRobif you could mate that would be great and verry much appretiated im missing it alredy Link to post Share on other sites
PhilGT93 Posted May 15, 2013 Author Share Posted May 15, 2013 boing Link to post Share on other sites
