garrygt Posted May 17, 2013 Posted May 17, 2013 Just went to put my water pump together, put it in with the gasket and tightened it up. Tried turning the water pump by hand and its turning but the impeller blades as scraping off the pump housing. It's a aisin water bump bought from I'd workz so everything should fit fine has anyone else had this problem and how did you get round it? Quote
turbo Grant Posted May 17, 2013 Posted May 17, 2013 Not heard of this before. Some one might have put the wrong pump on in the past and changed the housing that bolts to the block for a different one. That all I can think of Quote
StuDoc 72 Posted May 17, 2013 Posted May 17, 2013 Very strange mate? Unless there is a gasket missing that would cause it to sit out a little further? Idrees should be able to help may just be a faulty unit. Quote
glanzap802 Posted May 17, 2013 Posted May 17, 2013 I had a similar problem with a new water pump from id-works the blades were sticking out too far and wouldn't fit properly ended up getting all new pumps belts etc from Toyota as they are far better anyway the pump is still sat in my garage somewhere lol waste of money Quote
Idrees Posted May 17, 2013 Posted May 17, 2013 We only use Aisin pumps, they are the same as the ones Toyota supply. If you compare one of our pumps to a Toyota one side by side, they'll look exactly the same. When did you guys buy the pump (roughly)? We must have sold over 40 of these, I've used them myself a couple of times too. Can you send me a couple of pictures where it's fouling so I can show them to our supplier please? CheersIdreesID-Workz Quote
garrygt Posted May 17, 2013 Author Posted May 17, 2013 The gasket was in, the housing hasn't been changed either, it's as soon as you nip the bolts for the housing up it starts to rub inside the housing. Will go and get pics just now, I suspect its just faulty unit. Not sure how long ago I bought it iddy, I bought it along with a timing belt kit, oil pump, forged pistons and a gasket set. You may remember as I bought skat conrods from a boy on here then you gave me a good deal on the pistons. Quote
Idrees Posted May 17, 2013 Posted May 17, 2013 Yes indeed I do remember mate, not to worry anyway Garry as I'll sort you out with a new one and cover postage cost for sending that one back too. CheersIdreesID-Workz Ltd Quote
garrygt Posted May 17, 2013 Author Posted May 17, 2013 Nice one lad just waiting for the pics to upload to photobucket then I will stick them on here for you to see. Quote
garrygt Posted May 17, 2013 Author Posted May 17, 2013 The shiny bit is where it's been hitting the housing, you can't really see where the impeller blades have been scraping in the photo, you would have to have a closer look when I send it back Quote
Idrees Posted May 17, 2013 Posted May 17, 2013 Cheers, I'll get them sent over to our supplier too. I'll PM you the return address now, if you could PM me your address again please I'll get one sent out ASAP. CheersIdreesID-Workz Ltd Quote
mech5107 Posted May 17, 2013 Posted May 17, 2013 There are 2 pump types. One with the pulley pressed in and with the pulley bolted.The 2 pumps are not interchangable. Quote
