1990timeismoney Posted May 19, 2013 Posted May 19, 2013 Hi all got back of holiday yesterday drove car etc.opened bonnet while it was timing down and when it turned of there was a bit of pressure coming out of the rocket breather filter is this normal.Thanks Quote
TurboTobz Posted May 19, 2013 Posted May 19, 2013 You get some pressure yeah, you start to worry when its spewing oil out, same as if you take your oil cap out with the engine running, it'll have a small flow of air coming out. Quote
TurboTobz Posted May 19, 2013 Posted May 19, 2013 Check the pinned post at top of this page 'blowby' it shows you a little about it Quote
1990timeismoney Posted May 20, 2013 Author Posted May 20, 2013 Hi mate can't seem to find the post.So a bit of pressure release is normal when the engine switches of.Thanks for the help Quote
TurboTobz Posted May 20, 2013 Posted May 20, 2013 I'd check your pcv valve just to see if that's maybe knackered Quote
1990timeismoney Posted May 20, 2013 Author Posted May 20, 2013 Ok mate ill check that will it harm the engine if i use it till i get a new one Quote
