Get some auto sol metal polish and give it a good scrub mate. If its got oily residue inside flush it out with petrol or just run warm water through it till it clears, make sure to fill it, block both ends and give it a good shake.
As for the fins, get a small flatblade screwdriver and just seperate them, you'll prob find some will break off though which isn't good but can't be helped.
Autosols amazing for alloy polishing, really wouldn't touch the fins there so delicate as mentioned your more likely to cause damage and make it look worse than anything.
You can blow them through with pressurised air but if it's a strong gun dont hold it too close, and any bent fins can be adjusted with a screwdriver, but it's a nightmare lol.
