Hi guys just a quick question. My car seems to be suffering from rough idle. Only when I start the engine and it's still warm, never an issue when I start it from cold. Also it'll idle rough and then ill pull off and it'll drive fine then next time I stop and let it idle its fine again. Really annoying issue to be honest.
Anyone had these problems? Any ideas?
Thanks
Liam
just a sugestion mate clean the IDV with some carb cleaner and try it then..
my GT was awful at idle and used to hunt like a bitch.. cleaned this as it was full of gunk and sorted the problem out
it will take 2 mins..
side of the inlet mani with 2 bolts on it then unclip the pipe boom off.. wack some carb cleaner in with a straw fire away and watch the dirt fly out
Do you have a wideband? Probably your lambda sensor has cooled and reports wrong.
Mine does it and the rpms drop to about 650 and mixture leans to 16:1. Just a few blips to the gas pedal to raise temp and it's back again.
That if your lambda is single wire. If 4wire, check/clean the idle valve.
I don't have a wideband no! Thanks for the input though!
