Was refiting the dash again and was just about to go to disconect the battery and i heard somthing click and knew fine rightly i had blew somthing fs.. No power going to anything including the clocks, is there a main relay? Are what have i blown :( Thanks jamie.
Sorry ive got airbag light, oil light and handbrake light, thats all my reds i have, window wipers work but wont turn over when try to start
Won't be the main fuse if you have wipes and dash light. You have a stater relay in the fuse box. I would check the circuit opening relay above the glove box as well. And make sure you have power to the starter and getting a power to the trigger wire whilst cranking.
It will be a black relay and if you open the glove box it will be to the left. That's the main relay that cuts the power whilst cranking and the fuel pump runs throw it and stuff
I wouldn't expect a relay to fail after you take the dash out. It's very rare for them to fail at all. You said you took the dash out? If it was me I would be looking for a earth wire not connected
I was moving some wires near the clocks/speedo and heard something blow, hard to say were it came from mate, but it was inside the car :( worried I might have done more damage like ecu is fried :( wondering if it might be the EFI relay under the bonnet
If the efi relay had gone you would still be able to crank the engine over but it won't start. There is a big fuse up behind the drives side speaker. It doesn't look like a normal fuse tho. I would see if you have power on both sides of that.
Ill have a look when i get home from work, really starting to do my head in now... When you turn the key to start the radio gose off and all as it should when i turn it on the key but just no cranking, engine managment light isnt on eaither
Right ive checked a few relays under the bonnet and 2 under the dash, one behind the glove box and one beside the speaker, there clicking and all... Check the fuses under the steering wheel and IGN 5A fuse hasnt blown but isnt getting power sent to it, any advice were to go next before i rip the dash out again?
I'm sure there is a round fuse behind the speaker on the drivers side. It's a 30a if I remember right. I know it's linked up to central locking but might do other stuff as well
