glanzaman55 Posted May 30, 2013 Posted May 30, 2013 hi in need of help I recently bought a glanza drove it up the road it was perfect. left it off the road for about 3weeks now car will not rev past 5200rpm on full throttle on half throttle it will rev right up to 7800 no bother. got codes 24 ats 34 turbo pressure sensor and 41 tps. I have changed the turbo pressure sensor,ats,new iridium plugs new distributor cap new fuel filter,oil filter,and oil and new ht leads including king lead. changed ecu as I have one spare but still no luck. car was running 15psi of boost up the road now it will boost to 15 and drop to about 8psi. getting a new throttle position sensor at the weekend as its now jumping its idle and when driving its not settling its rev just keeps revving inbetween gear changes and if you dip the clutch it will rev itself to about 4500rpm for about 10 seconds then drop to 1000 then start jumping from 1k to 2k continuously any help appreciated thanks in advance Quote
jtaylor1990 Posted May 30, 2013 Posted May 30, 2013 Have u checked all boost hoses? If it hits peak pressure then drops it could be leaking from somewhere i.e intercooler piping etc Quote
glanzaman55 Posted May 30, 2013 Author Posted May 30, 2013 it all looks ok and no noises of air leaks Quote
glanzaman55 Posted May 30, 2013 Author Posted May 30, 2013 o yeah and I replaced idle control valve as copper bits inside were in many bits haha Quote
glanzaman55 Posted May 30, 2013 Author Posted May 30, 2013 its an absolute pain in the dick trying to have a play with people in their vxrs and eating through the gearbox haha Quote
glanzaman55 Posted May 30, 2013 Author Posted May 30, 2013 getting a new tps tomorrow night but would this cause it not too rev on full throttle I know that if it thinks butterfly is half open and its fully open I will be getting more air than fuel so would cut so possible and wiring all looks fine. thanks for comments Quote
glanzaman55 Posted June 24, 2013 Author Posted June 24, 2013 new throttle position sensor on new throttle body on new sensors on same mount as coil and still the same help please Quote
5T4R7ET N/A Posted June 25, 2013 Posted June 25, 2013 calibrate the TPS, guide here - http://www.toyotagtturbo.com/forums/showwiki.php?title=TPS+throttle+position+sensor+set+up+procedure Quote
glanzaman55 Posted June 27, 2013 Author Posted June 27, 2013 cheers mate I will try that when I get a moment Quote
glanzaman55 Posted July 1, 2013 Author Posted July 1, 2013 right all that setup still no luck but I did notice running car with no air filter or pipe makes it rev spot on and drives perfect as I noticed it was sucking the pipe inwards blocking air Quote
