What transmission i can use in a 4age rwd starlet ep82 ? My car is orignally fwd NA.I want to convert it into rwd....what transmission, rear diff and drive shaft i need to use pls help!!!! :help:
You can, will just be a lot of work, see what 4age powered kp starlets use.
Id guess a ae86 box but id you could use almost anything if you could get a conversion plate
Rear axle you could try use 4wd starlet rear axle.
Tbh i think you're in over your head I've you haven't got the slightest clue lol
