boosting24/7 Posted June 2, 2013 Posted June 2, 2013 I've just fited a forged engine into my starlet I went to drive it today and it seem its slow reving, and willnt drive as it same like someing is stoping it, lv checked all wireing ect, I got it driveing along the flat and it wouldnt go over 5mph, its doing my nut in, Any ideal will be great, Quote
AdamB Posted June 2, 2013 Posted June 2, 2013 Checked the cam timing? Checked the ignition timing? Quote
boosting24/7 Posted June 2, 2013 Author Posted June 2, 2013 hope you get it sorted mate I hope so to, I am thinking of breaking it, thats how pissed of I am atm Quote
boosting24/7 Posted June 2, 2013 Author Posted June 2, 2013 Checked the cam timing? Checked the ignition timing? I've checked the cam timing, it seems ok, mite be ignition timeing, how do I check that mate, Quote
Addymk2 Posted June 2, 2013 Posted June 2, 2013 Does it rev at idle? Unlikely BUT is your flywheel fucked? Quote
Taggy Posted June 2, 2013 Posted June 2, 2013 Defo timing issue, does your oil pump gear notch mark line up and then the 4e dot looking through the cam gear and also the two dots on the rear of the cams ? Quote
boosting24/7 Posted June 2, 2013 Author Posted June 2, 2013 Does it rev at idle? Unlikely BUT is your flywheel fucked? It idles fine and sound sweet, but when you rev it revs but is slow no missing or nothing its werid Quote
boosting24/7 Posted June 2, 2013 Author Posted June 2, 2013 Defo timing issue, does your oil pump gear notch mark line up and then the 4e dot looking through the cam gear and also the two dots on the rear of the cams ? Done the 4e to dot through the hole, then to the 0 on bottom pully, Quote
boosting24/7 Posted June 2, 2013 Author Posted June 2, 2013 Try setting up the TPS mate. Sorry mate all new to these starlets.... what tps Thanks ben Quote
AdamB Posted June 2, 2013 Posted June 2, 2013 Sorry mate all new to these starlets.... what tps Thanks ben Throttle position sensor mate. Check here for the setup http://www.toyotagtturbo.com/forums/showwiki.php?title=TPS+throttle+position+sensor+set+up+procedure And here for the ignition timing http://www.toyotagtturbo.com/forums/showwiki.php?title=How+to+set+timing Quote
boosting24/7 Posted June 2, 2013 Author Posted June 2, 2013 Throttle position sensor mate. Check here for the setup http://www.toyotagtturbo.com/forums/showwiki.php?title=TPS+throttle+position+sensor+set+up+procedure'>http://www.toyotagtturbo.com/forums/showwiki.php?title=TPS+throttle+position+sensor+set+up+procedure And here for the ignition timing http://www.toyotagtturbo.com/forums/showwiki.php?title=How+to+set+timing'>http://www.toyotagtturbo.com/forums/showwiki.php?title=How+to+set+timing Thanks il try and get hold of a meter, tomorrow and have a play with it tomorrow thanks angen Quote
boosting24/7 Posted June 3, 2013 Author Posted June 3, 2013 All fix now was, dizzy timeing was out, Thanks for all your help peeps Quote
