Use a dremmel and in number 3 you will see there is a lump. Just grind that flat.
You can go along and open all 4 up a little and just give them a general clean while your at it.
As for the stud. Whats in the way?
Im assuming you have the hot pipe off the turbo?
Make sure u have a socket, extention, Universal Joint and a spanner and you should be able to get everything off.
Upload the pic to photobucket either on a pc or app on your fone. Then copy and paste the img code in this thread and the pic will appear.
Aye mate give it a go because Im really not sure why its so difficult so would like to see for myself.
