steve-gers Posted June 15, 2013 Posted June 15, 2013 I am in the process of changing from an Exedy 3 puck to a spec 6 puck but the Spec has no release with the kit I bought (2nd hand). Would the Exedy one be ok to use or not as I have noticed different clutches have different styles of bearings? If it is not ok to use what type can I use and where can I get one from? Quote
turbo Grant Posted June 16, 2013 Posted June 16, 2013 You should be ok with the one you have. The only ones that your need a different bearing for is the orc and blitz clutches Quote
mikey4410 Posted June 16, 2013 Posted June 16, 2013 yea i would say so also,exedy i used my old bearing on also Quote
Fizturbo Posted June 16, 2013 Posted June 16, 2013 Am usin a 6 puk, replaced the noisy release bearing with a standard bearing an has been fine. Quote
