Chrishoughton1989 Posted June 19, 2013 Posted June 19, 2013 Worth the money ? Worth having ? As looking at upping the boost soon. Thanks. Quote
TurboTobz Posted June 19, 2013 Posted June 19, 2013 Without a doubt a widebands Definately worth the money. Quote
mech5107 Posted June 19, 2013 Posted June 19, 2013 ΑΕΜ is one of the best for everyday use... no calibration needed, accurate enough, easy to install... Quote
Chrishoughton1989 Posted June 19, 2013 Author Posted June 19, 2013 Buying now !!! When fitted what reading am I looking for Quote
Weyro Posted June 19, 2013 Posted June 19, 2013 14.7 on idle and with light throttle cruisingand anything lower than 12 when at full throttle and boost just a rough guide, depends on your setup too Quote
Broony Posted June 19, 2013 Posted June 19, 2013 yeah iirc 14.9 is a perfect stoich (or however its spelt) on idle like the lad above said lower is better on boost oh and they are the best piece of mind you can have running a turbo car Quote
mikey4410 Posted June 19, 2013 Posted June 19, 2013 innovate is the one i have gone for,had one befor,sooo easy to use and cheap at 150 quid. at full throttle u wana be aiming for 11.4 or 11.5 to be very safe. Quote
Weyro Posted June 19, 2013 Posted June 19, 2013 yea i should have said that 14.7 exactly isnt too important, you can be slightly richer or leaner and itll be fine personally i like to be slightly richer(lower) at cruise and idle Quote
Chrishoughton1989 Posted June 19, 2013 Author Posted June 19, 2013 Thanks. Will report bk with outcome when fitted hopefully weekend. Quote
Chrishoughton1989 Posted June 30, 2013 Author Posted June 30, 2013 Hello all! mine is reading 14.6 ish on light throttle and tick over and low 12 - 13 on hard acceleration? Any good ? Thanks. Quote
AdamB Posted June 30, 2013 Posted June 30, 2013 (edited) Whats your setup mate? Seems a little high for WOT. Edited June 30, 2013 by AdamB Quote
Weyro Posted June 30, 2013 Posted June 30, 2013 Yea thats not quite rich enough, you want it to be between 11-12. Do you have an adjustable fuel pressure regulator? Quote
Chrishoughton1989 Posted June 30, 2013 Author Posted June 30, 2013 Yes I do, do I just literally turn it up ? Quote
Chrishoughton1989 Posted June 30, 2013 Author Posted June 30, 2013 (edited) Ct9b, Front mount. Manifold. Full exhaust. External wastegate. Afpr. Fcd. Bar boost. Relocated filter. That's about it Edited June 30, 2013 by Chrishoughton1989 Quote
TurboTobz Posted June 30, 2013 Posted June 30, 2013 What FCD? If its not jam what numbers itSet on? Quote
AdamB Posted June 30, 2013 Posted June 30, 2013 Has it ever been setup by a tuner? If not I would get it done very soon. Quote
Chrishoughton1989 Posted June 30, 2013 Author Posted June 30, 2013 Thanks. I think it has in past. 12 on a hks fcd. Thanks. Quote
AdamB Posted June 30, 2013 Posted June 30, 2013 Isn't 12 the highest? I'm sure 12 means off? Would be best to get it setup by a tuner tbh mate, or it could end up in disaster. Quote
Chrishoughton1989 Posted July 1, 2013 Author Posted July 1, 2013 I'm not sure tbh lol. Where would set if up ? Thanks. Quote
AdamB Posted July 1, 2013 Posted July 1, 2013 Never used one but I'm sure thats what I've read before that 12 is off. Any tuner with a wideband and det cans should be able to set it up for you, but make sure they have experience with fiddling with fcd's. Not too sure on your area but I would have thought there's plenty of places round your way who have the ability to map a car Quote
Chrishoughton1989 Posted July 1, 2013 Author Posted July 1, 2013 Strange. Why don't I hit fuel cut of its off ? Quote
AdamB Posted July 1, 2013 Posted July 1, 2013 Don't know am just guessing as I've never used FCD's. But am sure thats what I read, might be a Jam unit I was thinking of. Quote
TurboTobz Posted July 1, 2013 Posted July 1, 2013 (edited) 12's off. 7-8 is the recommended settings, 8 if you can some cars only like 7.1 is full on cut, most affect to the signals provided to ECU 12s standard cut.Jam fcds don't have adjustment iirc, they just come into action after fuel cut. Edited July 1, 2013 by TurboTobz Quote
Chrishoughton1989 Posted July 1, 2013 Author Posted July 1, 2013 Mine is on 12 on standard ecu ? Quote
