On a glanza v forged engine with this list of mods. What bhp you think after a remap? Just interested.
Wiesco 74.5mm Low Compression Piston Kit with Rings and Pins
Scat 4EFTE Forged Conrod Kit with ARP Rod Bolts
Genuine Toyota Headgasket
Genuine Toyota Full Gasket Kit
Genuine Toyota Oil Pump Kit
OEM Water Pump Kit
OEM Cambelt Kit inc Idler & Tensioner
OEM Headbolt Kit & New Washers
ACL Main Bearing Kit
ACL Big End Bearing Kit
ACL Thrust Washer Kit
Fully Machined and Polished 4EFTE Bottom End
Fully Stripped, Cleaned and Rebuilt 4EFTE Cylinder Head to Standard Spec
New Magnecor 8.5mm HT Leads
New NGK Iridium Spark Plugs
New Distributor
New Coil Pack
New Exedy Stage 1 Organic Clutch + Pressure Plate
New OEM Flywheel
OEM LSD Gearbox
Magnetic Sump Plug
Oil Catch Can
Chrome Rocker Cover Nuts
Various Pink Vac Hoses
A/C Removed
Hi/Low Boost Removed
550CC Pink Injectors
Dastek UniChip Q Piggyback management
Apexi AFC - Air Flow Controller
AEM Boost Controller
Turbo & Exhaust;
Vf24 Subaru P1 Turbo
TM Developments Ram Horn Exhaust manifold
De-cat Downpipe
5zigen Pro Racer Full Exhaust System
TM Braided Oil Line
Braided Water Lines
Tial 38mm Wastegate
Custom Screamer Pipe
1.1-1.2bar, anymore then that and the turbo won't last long. They shit themselves over 1.4bar.
Edited by DevonGT
Depends what you want to use it for, 22s have been used on starlets and get good figures. 24 is one of the, if not the, smallest VF with spool times similar to a TD04.
The VF22 is good for upto like 380-400bhp, which imo won't make a good road car as it uses the largest exhaust P20 housing.
VF24 would be ideal, or if you want a little more punch the VF23 or VF28.
