DavidAshton Posted June 30, 2013 Posted June 30, 2013 Anyone had issues with the TAIL fuse constantly blowing? That's on the internal fuse box.It takes out the dash cluster bulbs, rear bulbs, rear number plate bulbs and front sidelights. I have checked all visible wiring and can see no issues? As soon as I put a new fuse in it blows instantly. Any one had this particular issue before? If not any ideas to help pin point the issue? I have 7 new fuses left and want to sort it today as I can't drive at night now :-(My next step is going to be ripping the plastics out to see more of the loom...... Quote
5T4R7ET N/A Posted June 30, 2013 Posted June 30, 2013 it must be shorting out on something, even a rusty connector to a bulb can cause this. take out every bulb on that circuit the and have a look at the contacts. also take the driver side speaker plastic out and look at the wires that go into the fuses. have any extra wires been wired in for gauges or something? Quote
philfrost432 Posted February 10, 2014 Posted February 10, 2014 Hi mate got the same problem i have used 30 fuses trying to sort it out with no luck really annoying me now, did you sort yours out ? if so can you tell me how please cheers phil Quote
