DR3W-MURR4Y Posted July 2, 2013 Posted July 2, 2013 Right guys gotta change head gasket on my starlet, bought an engine of someone as a "good engine" so just dropped it straight in to find out the head gasket is fried!So.. What like of a job is the gasket change with setting up timings etc and what gasket would u advise on using? Quote
daveEP Posted July 2, 2013 Posted July 2, 2013 Its quite quite a big job mate. but not imposible to do if u know your way around the engine. Am sure there should be a wiki on it on here. best to see idrees for a gasket he will point u in the right direction for the best gasket for your setup and can order it straight up for u. ;) Quote
AdamB Posted July 2, 2013 Posted July 2, 2013 Providing you have some mechanical knowledge its fine. Take pics of every stage, keep things in order, label things if you need to. Just stay organised and its a doddle really. The timing is a piece of cake, nothing to worry about, and if you get it wrong it won't do any damage what so ever as they are a non-interference engine. Whats your setup? You'll most likely be fine running a stock gasket. Make sure to get the head skimmed though. Quote
daniel_g Posted July 2, 2013 Posted July 2, 2013 Few tutorials on TGTT to look through http://www.toyotagtturbo.com/forums/showwiki.php?title=Info:Maintenance+and+Repair. If doing a HG i would recommend changing other service parts whilst your at it, mainly waterpump, timing belt kit, headbolts obv. Quote
