My cars gears are sticking, like when am driving from 1st to 2nd feels like it doesnt want to come out same with 2nd to 3rd any ideas guys as its pissing me right off :)
Slave cylinder packing up maybe ? Fluid need changing ? :)
This only happend after clutch replacement and there is a slight noise and when u put the clutch down it goes away, everything was fine before the new clutch
That sounds like release bearing trouble bud :)
That's what I thought but td assurd me it was the input shaft bearing? How can u tell with out taking the gear box off? It was fine before they changed the clutch and all of a sudden it's the input shaft bearing :/ I don't get it
The shaft bearing has no impact on the way gears are engaged or disengaged. The shaft bearings are there to simply support the load of the shaft.
Could be a few things :
Fluid change
Slave cylinder
Release bearing
Selector fork
Fluid change
Slave cylinder
Release bearing
Selector fork
Fluids been changed whist they changed the clutch, release bearing
Was changed with the spec clutch? Car
Was fine before the clutch change now it's making a sound and it goes away when u put the clutch down and it's also sticking in gear now don't know what to do after spending all that money
If its making a noise when the clutch pedal is depressed then thats the release bearing. There's only a couple of clutches that make that noise and I've never heard of the Spec clutch doing it before. Blitz and ORC Ogura are the main ones which make a like rattling noise.
Another problem that sometimes happens with aftermarket clutches is that the slave rod creates drag, to overcome this a longer slave rod needs to be fitted. Only ever heard of this problem with Competition clutches, but am sure theres others that have the problem.
Edited by AdamB
I'm the only one having a problem with this spec 6 paddle cluch.....
Am sure it's the release bearing tho as before the clutch was replaced it was fine
Would the release bearing cause the bearings to stick?
The release bearing would make it hard to select gears yeah. Who replaced the clutch mate? I'd take it back to them and get them to sort it.
Drop yaristurbo a pm mate, he works for a transmissions place so he'll deffo be able to give you an answer.
Edited by AdamB
Tuning developments did mate.... It is stiff going
In to gears somtyms iswell mate
They did have a look at it just by listening
To it and they said its the input shaft bearing which I dont think it could be as it was fine before i gave it them when I went to collect it
The noise was there iswell but I thought it
Was the engine as it needed running
In thought it was piston slap or somthing lol
Nah I highly doubt it would be the shaft bearing if it was fine when it went in. To me anyway it sounds something to do with the release bearing or the slave cylinder.
That's what am saying bud they said it was the shaft bearing and sent me on my way and now am stuck.....
Everyone that I've spoke to has said its the realease bearing
The thing that gets to me the most
Is that it was a brand new spanking
Clutch with a brand new realease bearing and it
Was fuked the day I got
The car bak so why should I have to pay more to
Get it sorted am so fuming spent nealy 3 grand on the car and it's still not right
Shows once u spent the money people don't
Want to know after that
I have known brand new release bearings to be stuffed, its a pain in the ass to have to take the gearbox back off though. Although its not so bad on a starlet.
Seem's like your in a bit of a shit situation mate, might be worth asking Mike if they can just take another look as your not happy with the way the car is. Are you far away from them?
Am about 90 miles from them, and they don't want to sort nothing I've already spoke to mike about it loads first he goes bring
It down then I'll have a look when u bring it down for mapping so I did that and then they didn't
Mention nothing about it till I told them, then they had a quick look and said it was the input
Shaft bearing...... He goes we can strip it and if
It turns out not to be the release bearing there gna charge me for labour which is fair enuff
But tbh it's got to that point now were I just don't
Know what there going to do, I just don't trust them now incase it is the realease bearing
And they just say its the input shaft bearing and charge me for labour, so my plan is to take it to somone else and if it turns out to be a fuked realease bearing or cluch I will be taking action :)
Best to get a second opinion on it mate. Maybe if you have a transmission specialist local to you it might pay off to drive the car down to them and get one of their employee's to drive it etc and give you some more feedback :)
Will have to sort somthing out will be taking it to someone after japfest 2 thanks for you're help appreciate it :)
Doesn't sound like td are willing to admit fault but im sure there's others on here that more about this issue
I know mate after spending all that money u would think a reputable company like TD would sort it no problem now am stuck in the middle....
Will be taking it to someone local after japfest and if it does turn out to be the clutch or release bearing I will be striaght on the phone to td
Seen this problem a few times specifically on exedy paddle clutches. Can happen when they crack/pop the springs out of the plate...that or release bearing. Take the box off and have a look.
  • 4 weeks later...
I fitted a spec 6 stage 4 on mine a while ago from TD and the release bearing is as noisy as the one I took off after 1300miles ! While its working I ain't messing about taking box off again Lol my gears were sticking too but I've found its a combination of the gear cables needing lubrication and the clutch slave cylinder having too much play ..
